Kona 3 - Video Output problem
Jonny Hal
on Jan 8, 2011 at 11:56:33 pm
I can't seem to get any output from my Kona 3 card -- just a test pattern.
Usually, when I switch between the FCP and any other app, I would notice a flip from my FCP edit to the default test pattern (set in the AJA) tool.
Now, there's no flip and the only thing I get is a test pattern or whatever I set as the Default Output in the AJA tool.
I trashed my FCP plist
I created an Easy Setup 8-bit uncompressed NTSC project
None of these work.
I'm going out of the Kona 3 - thru the breakout box -- component beta into a Sony 40 XBR.
Any help would be appreciated.
John Pale
Re: Kona 3 - Video Output problem
on Jan 9, 2011 at 12:04:06 am
Uninstall and re-install your kona drivers
Jonny Hal
on Jan 9, 2011 at 12:09:35 am
duh - my output frames were set to none.
eek.
