AJA LHi Problems capturing HDMI
Alen Jelic
on Dec 9, 2010 at 7:31:12 pm
hey guys,
I'm having a bit of trouble...
I just bought the AJA LHi Card & the Box ... Everything seemed to work fine.. until I wanted to capture via HDMI...
once I connected the Cam to the Break out box via HDMI I was shocked. The picture was PINK !!! And the colors where not as they should be. I tried everything. Even connected the cam direct to the card even skipping the B-OutBox..
Nothing changed.. FCP = PINK and even the AJA VTR Xchange = PINK
Some colors are right but everything wath has to be white is PINK.
But to be shore that the Problem is just considering the HDMI, I tested the HD SDI Input everything worked just fine..
but that dos not solve my problem.
The cam has only HDMI out.
I want to capture HD Uncompressed
so if any of you got a tip... pleas help me ....
p.s. I even hooked my Apple TV via HDMI to the card = PINK :(
greets
Alen
Shane Ross
Re: AJA LHi Problems capturing HDMI
on Dec 9, 2010 at 9:35:26 pm
Try another HDMI cable?
Shane
Alen Jelic
on Dec 9, 2010 at 10:16:16 pm
I tried 3 different cables ...
Nothing helped :(
Shane Ross
on Dec 9, 2010 at 10:21:34 pm
Potential hardware issue. I'd call AJA.
Shane
Alen Jelic
on Dec 9, 2010 at 10:29:13 pm
hmm thats what I thought as well...
I tried the same thing whit my AJA IO HD and everything worked fine ..
But I'm still hoping to find a way out. And not to send the card to the shop and wait days until l get the new one ..
Alen Jelic
on Dec 9, 2010 at 11:01:00 pm
I just talked to AJA..
They told me it it's a software Problem which will be fixed with the new Update.
The new Update should come at the end of december.
So this means Downgrade or Wait ....
