10-bit RGB uncompressed with FCP
Dan Goulder
on Nov 29, 2010 at 12:36:34 am
Can you please tell me which of the following pieces of software can import and export footage in the Aja 10-bit RGB uncompressed codec without truncating the color depth? I want to be able to add effects to footage that will open on the FCP timeline, using that preset, without having to render the footage in Final Cut, which as far as I know still will not render in full 10-bit RGB.
After Effects?
Photoshop?
Premiere Pro?
Combustion?
Motion?
Which other effects software can successfully export this codec (by leaving the codec intact)?
Thank you.
