Working with 720x540 sequence
Michael Niemcewicz
on Oct 12, 2010 at 6:06:08 pm
I'm outputting the video to the NTSC 4:3 SD 720x486 that was shot and edited in HD. Sony EX format uses square pixels so I figured that for downconversion I would create a custom 720x540 square pixels sequence. Another reason would be that our graphic elements are rendered in that size.
Kona has no problem playing that but I'm not sure what it actually does on the output end: converts square to rectangular pixels and resizes the frame to 720x486? Or chops the picture by 54 pixels?
Is there a better way of dealing with this whole 1920x1080 HD -KONA- 720x486 SD conversion?
Jeremy Garchow
Re: Working with 720x540 sequence
on Oct 12, 2010 at 6:23:56 pm
[Michael Niemcewicz] "Sony EX format uses square pixels"
What? Not in SD, or even HD if shooting 1440x1080.
I'd work in an HD timeline, then use the Kona for a hardware center cut down-convert.
Jeremy
