1024x768 monitoring.
David Hildreth
on Sep 22, 2010 at 11:56:36 pm
I'm working on a project in FCP with a Kona 3 at a 1024x768 resolution. The videos are for iPads, so we decided to work at the native resolution. The problem is getting it to look right on our monitors as we're working.
In After Effects I can monitor at 720p and check a box to preserve the aspect ratio, so it ends up pillar boxed inside of 1280x720. Any ideas on how I can get Final Cut Pro to do the same?
gary adcock
Re: 1024x768 monitoring.
on Sep 23, 2010 at 10:14:15 am
[David Hildreth] "I'm working on a project in FCP with a Kona 3 at a 1024x768 resolution. The videos are for iPads, so we decided to work at the native resolution"
Nope.
The Kona's will only deliver SMPTE video frames out of FCP,
However- please note that The iPad will properly playback 1280x 720 HD materials- save yourself the grief and use 720 if you want to monitor your video correctly.
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
http://blogs.creativecow.net/24640
Jeremy Garchow
on Sep 23, 2010 at 5:51:25 pm
[gary adcock] "However- please note that The iPad will properly playback 1280x 720 HD materials- save yourself the grief and use 720 if you want to monitor your video correctly."
I totally agree.
At the very least, work in SD (4:3) and then resize to 4:3 square pixels and the other raster size later.
David Hildreth
on Sep 23, 2010 at 5:53:25 pm
Well, it's going in an app and really works best in 4:3 at the native resolution. Thanks for the input. It's all unsupervised, so monitoring isn't the world's biggest issue.
Jeremy Garchow
on Sep 23, 2010 at 5:56:13 pm
[David Hildreth] "so monitoring isn't the world's biggest issue."
That's funny, the subject seems to make me think so. ;)
David Hildreth
on Sep 23, 2010 at 5:58:00 pm
haha, serious enough to make a forum post about it I guess.
Michael Sacci
on Sep 24, 2010 at 5:27:09 am
What about working in a 1280x720 sequence, place the 1024x768 clips so it floats in black, then at the end, crop the black off in Compressor. May get a little loss of quality for RT playback but it is worth a shot.
