AJA Kona 3 downconvertion
Yiannis Valkan
on Sep 21, 2010 at 10:51:23 am
Hi all,
I would like to know if AJA KONA 3 can downconvert realtime from 1080i or 1080p to SD.
For eg. to import to AJA HD and output SD.
Is that possible?
gary adcock
Re: AJA Kona 3 downconvertion
on Sep 21, 2010 at 10:58:43 am
[Yiannis Valkan] " would like to know if AJA KONA 3 can downconvert realtime from 1080i or 1080p to SD.
For eg. to import to AJA HD and output SD."
Not from 1080 True P sources ( Red)
Use the 1080i or PSF settings and the downconversion will work fine.
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
http://blogs.creativecow.net/24640
Yiannis Valkan
on Sep 21, 2010 at 11:00:50 am
hi and thanks for that quick answer.
The source will be an HDCAM SR video player.
So i guess that is fine?
2 minds are better than one.
Mark Spano
on Sep 21, 2010 at 7:21:46 pm
I would like to add that if the SR tape is 1080i, the SR has a built-in downconvert, which you can choose letterbox, edge-crop, or anamorphic. And if your SR has the format converter option card installed, you can also add pulldown and downconvert 1080p SR tapes.
