SAS raid reccomendations
jason levy
on Aug 10, 2010 at 10:11:24 pm
Hi all,
I guess this is not strictly a Kona question but since this is where I hang out I thought I'd post it here.. hope that is ok.
Looking for an SAS raid enclosure to replace my current ProAvio tower which has died. I don't want to go with ProAVIO again. What I want to do is buy something I can just slap the 8 1TB SATA drives I had in the Pro Avio box into and hook up to my ATTO R380.
Any suggestions on a good box?
thanks
Jason
walter biscardi
Re: SAS raid reccomendations
on Aug 10, 2010 at 10:34:26 pm
WeibeTech RTX series (though not sure if they have an SAS version, you can check on the website.
Maxx Digital
Small Tree Electronics
Sonnet
Dulce
All of those manufacturers make excellent SAS / SATA arrays. We run 48TB of Maxx Digital Storage. 32TB of it runs off an Ethernet SAN with Small Tree electronics magic. We also have two of the WiebeTech RTX units that we use for archiving, though they can also be set up in RAIDs.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media
"Foul Water, Fiery Serpent" featuring Sigourney Weaver coming soon.
Blog Twitter Facebook
jason levy
on Aug 10, 2010 at 10:39:29 pm
Thanks Walter. That is appreciated.
jason
John Fishback
on Aug 12, 2010 at 9:31:14 pm
We use a PDE enclosure with 8-drives running off a R380. It works great.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
jason levy
on Aug 16, 2010 at 7:40:38 pm
Thanks John.
Peter McAuley
on Sep 2, 2010 at 6:58:32 pm
I've been looking at the Proavio raids along with the R380 as well. What happened to yours that you don't like.
Peter McAuley
AXYZ
Toronto
jason levy
on Sep 3, 2010 at 5:00:03 pm
I feel bad for not updating this post..
It's a long saga, but in the end the Proavio box is fine.
What happened in brief was that the setup never quite functioned right initially and we could not do much because it was in service and there was a huge amount of media on it. The atto utility kept reporting that the drives were "degraded", and could not be rebuilt, though it still worked. When the project was done I tried to re-stripe it and it failed every time.
I asked the dealer I bought the unit and the atto from for support.. and he told me that he was very sorry but they had been having complaints about the Proavio box and he no longer carried it and would not support it. He of course offered to sell me something else. He said that there was an incompatibility with the chip in the Proavio that caused problems and there was no way to fix my problem.
Finally (not sure why I waited) I called Proavio tech support and the guy was great and solved the problem. It was simply that the ATTO card was in too slow a slot. It's running in one of the Mac Pro's that use a utility to to set the speed of the various slots. I am running a configuration that is approved by Kona and it all works but we cannot format the raid 5 in that configuration. Finally with the help of the guy from Proavio I sped up the slot and was able to format the raid 5 and then put it back the way it was so the Kona would work properly and now everyting is working perfectly.
Regarding the supposed "incompatibility" the guy from Proavio knew what that was about. Aparently some model of Seagate drive (you can call proavio tech support and ask which) do not work with the chip set of certain of their boxes..
All's well that ends well. Proavio has great tech support. The guy was good.
Jason
John Fishback
on Sep 3, 2010 at 5:55:07 pm
Tech support is so critical. When we put together our system, ATTO and our integrator were amazingly helpful. We faced the firmware issue that affected some Seagate drives. We couldn't do the firmware fix ourselves since we're a Mac shop with only a couple of PCs and none with the specs needed. So our integrator took back the drives, updated the firmware and had them back to us a day later.
John
