true 1080p display?
Joel Arvidsson
true 1080p display?
on Aug 5, 2010 at 5:47:34 am
Recap.
Hi is it possible for a plasma to show 1080p or does it always display 1080i. Now they added 1080p to the easy setup but but not for dvc prohd. I think I have read here that i doesn't matter if you would set the output to 1080i (which i must since i cut in dvc prohd) cause the display will always show interlaced in 1080. Just wanted to make this clear.
thanks
joelarvidsson@gmail.com
Joel Arvidsson
Re: true 1080p display?
on Aug 5, 2010 at 10:24:07 am
I found the post i been reading. In 1080p you always display interlaced.
1080 content always plays back as interlace on a monitor, it is the nature if the format called a progressive segmented frame or PsF."
walter biscardi
on Aug 5, 2010 at 11:46:26 am
If you have a 1080p Plasma, sure. Panasonic has a few out there now.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media
"Foul Water, Fiery Serpent" featuring Sigourney Weaver coming soon.
Blog Twitter Facebook
Jeremy Garchow
on Aug 5, 2010 at 5:23:00 pm
you can always send a 1080p signal and check. You don't need an easy setup for it.
