KONA 3 cross convert 720p24 to 1080i with HDCAM SR
Mike Merkwan
on Jul 12, 2010 at 9:12:22 pm
is this possible. when i try to match up the settings, they just stay greyed out. Was wondering if any of you guys have done or do this on a regular basis. Was figuring i may need some different hardware. Thanks.
the rats are getting fat while good men die...
http://www.myspace.com/battleflask
Jeremy Garchow
Re: KONA 3 cross convert 720p24 to 1080i with HDCAM SR
on Jul 12, 2010 at 9:24:54 pm
If going dual link to SR no, it won't work.
Mike Merkwan
on Jul 12, 2010 at 9:47:37 pm
You mean not have the dual link option enabled or not have the cables hooked up at all? We're not in dual link. Thanks Jeremy.
Jeremy Garchow
on Jul 12, 2010 at 10:55:38 pm
Cool. If laying off single link, then keep FCP in your 720p easy setup and set the appropriate SDI output that's hooked up to your deck in the secondary mode using the Kona control panel.
Then set the video output to 1080i in Fcp in the 'View' menu.
Jeremy
gary adcock
on Jul 13, 2010 at 12:06:49 am
[Jeremy Garchow] "If going dual link to SR no, it won't work."
actually yes it will
When you loaded the latest version of the Kona Drivers there is a specific setting to install the cross conversions I am not sure that it is a default anymore.
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Technology Development
Quality Assurance Assistance
Chicago, IL
http://blogs.creativecow.net/24640
Jeremy Garchow
on Jul 13, 2010 at 4:17:27 pm
[gary adcock] "When you loaded the latest version of the Kona Drivers there is a specific setting to install the cross conversions I am not sure that it is a default anymore. "
I stand corrected. It does work. Sorry about the false info.
Mike, for dual link layoff you would go to the AJA Control Panel and right click on the SDI1 output triangle and choose 'dual link' from the drop down. Then back in FCP, you'd choose a 1080i 29.97 easy setup that matches your original 720p sequence codec. For example, if you are working in DVCPro HD, then you'd hit control-q and choose the 1080i29.97 DVCPro HD easy setup. Thanks to Gary.
Jeremy
Doug Beal
on Jul 14, 2010 at 1:36:29 pm
The other option if you plan to keep a 23.98 master would be to output 23.98 to the SR then re-injest at 29.97 with SR doing the frame rate conversion (1080iPD)
Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN
Mike Merkwan
on Jul 14, 2010 at 9:18:25 pm
Thanks alot guys. You never fail me, and im constantly learning from you. I really appreciate it. Take it easy. -Mike
