FCP quits unexpectedly
Nanette Binon
on Jul 12, 2010 at 6:58:00 pm
I have tried everything to open this app-trashing prefs, resetting PRAM, verifying disk-all to no avail.
Can someone please help me?
I get this problem report when FCP quits:
Process: Final Cut Pro [257]
Path: /Applications/Final Cut Pro Old.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 5.0.4 (5.0.4)
Build Info: FCPApp-512141418~2
Code Type: PPC (Translated)
Parent Process: launchd [109]
Date/Time: 2010-07-12 01:59:22.524 -0700
OS Version: Mac OS X 10.6.4 (10F569)
Report Version: 6
Interval Since Last Report: 14789 sec
Crashes Since Last Report: 44
Per-App Crashes Since Last Report: 44
Anonymous UUID: 9B54DD71-A7DE-440D-A17D-B63CCDAD53A8
Exception Type: EXC_CRASH (SIGTRAP)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x802362b2 __pthread_kill + 10
1 libSystem.B.dylib 0x80235b5f pthread_kill + 95
2 com.apple.FinalCutPro 0xb80bfb30 0xb8000000 + 785200
3 com.apple.FinalCutPro 0xb80c0037 0xb8000000 + 786487
4 com.apple.FinalCutPro 0xb80dd8e8 0xb8000000 + 907496
5 com.apple.FinalCutPro 0xb8145397 spin_lock_wrapper + 1791
6 com.apple.FinalCutPro 0xb801ceb7 0xb8000000 + 118455
Thread 1:
0 libSystem.B.dylib 0x801400fa mach_msg_trap + 10
1 libSystem.B.dylib 0x80140867 mach_msg + 68
2 com.apple.FinalCutPro 0xb819440f CallPPCFunctionAtAddressInt + 206231
3 libSystem.B.dylib 0x8016d81d _pthread_start + 345
4 libSystem.B.dylib 0x8016d6a2 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x802f8500 ecx: 0xb7fff9ac edx: 0x802362b2
edi: 0xb8211640 esi: 0x00000005 ebp: 0xb7fff9d8 esp: 0xb7fff9ac
ss: 0x0000001f efl: 0x00000286 eip: 0x802362b2 cs: 0x00000007
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x802362a8
Binary Images:
0x80000000 - 0x8005bff7 com.apple.framework.IOKit 2.0 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x8007a000 - 0x800e4fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) /usr/lib/libstdc++.6.dylib
0x8013f000 - 0x802e5feb libSystem.B.dylib 125.2.0 (compatibility 1.0.0) /usr/lib/libSystem.B.dylib
0x80366000 - 0x804e0fe3 com.apple.CoreFoundation 6.6.3 (550.29) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x805d8000 - 0x805e6fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) /usr/lib/libz.1.dylib
0x805eb000 - 0x805f7ff7 libkxld.dylib ??? (???) /usr/lib/system/libkxld.dylib
0x805fb000 - 0x80641ff7 libauto.dylib ??? (???) /usr/lib/libauto.dylib
0x8064e000 - 0x807d0fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) /usr/lib/libicucore.A.dylib
0x80832000 - 0x808dffe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) /usr/lib/libobjc.A.dylib
0x808f3000 - 0x808f6fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) /usr/lib/system/libmathCommon.A.dylib
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) /usr/lib/dyld
0xb8000000 - 0xb81defff com.apple.FinalCutPro 5.0.4 (5.0.4) /Applications/Final Cut Pro Old.app/Contents/MacOS/Final Cut Pro
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
Translated Code Information:
objc[257]: garbage collection is ON
NO CRASH REPORT
Unable to gather system configuration information.
Jeremy Garchow
Re: FCP quits unexpectedly
on Jul 12, 2010 at 7:42:23 pm
FCP v5.0.4 and OS 10.6.4?
That might have something to do with it.
Joseph Owens
on Aug 2, 2010 at 7:46:42 pm
I started getting this kind of behaviour last October when I committed the serious error of upgrading to Snow Leopard.
For me the situation stabilized a bit with the Non-Desktop Driver (NDD) version of the latest Kona3 software. Now I get occasional panics with FCP errors using the Kona plugin which results in a system crash. Most annoyingly, the Edit to Tape module is just insane with frequent hangups on the 9-pin RS422 control, which nothing but a full system shutdown and restore will fix.
jPo
You mean "Old Ben"? Ben Kenobi?
