Audio Crackles from FCP 7 through Kona Card
Jake Diamond
on Jul 12, 2010 at 6:23:26 pm
Hello,
My system was recently upgraded to FCP 7.02 from 6.05 and the Kona LHi control panel was upgraded to Version 8.0. I'm working on a Pro Res 1080i 29.97 sequence and now when I play any clips or sequences externally, the audio crackles and sometimes there are thin lines through the video on the external monitor. If I play the clips with External Video Monitoring turned off, the clips are fine, no crackling, no lines - only when playing everything externally. This is a problem because I'm going to have to output to HDCAM in a few days.
If anyone has experienced this, or has any ideas on how to fix it, I'd greatly appreciate any advice.
Thank you,
Jake
OS 10.5.8
2 x 2.66 GHZ Quad-Core Intel Xeon
8 GB 1066 MHz DDR3
FCP 7.02
Quicktime 7.6.6
Jeremy Garchow
Re: Audio Crackles from FCP 7 through Kona Card
on Jul 12, 2010 at 6:50:57 pm
[Jake Diamond] "and the Kona LHi control panel was upgraded to Version 8.0"
Did you uninstall the older drivers before installing the new ones?
gary adcock
on Jul 12, 2010 at 7:24:04 pm
[Jeremy Garchow] "Did you uninstall the older drivers before installing the new ones?"
AND did you update the firmware manually? it is not an automatic process.
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Technology Development
Quality Assurance Assistance
Chicago, IL
http://blogs.creativecow.net/24640
Jake Diamond
on Jul 12, 2010 at 7:40:22 pm
Gary,
Sorry - I should have done more research before asking - I don't know the answer to this either as it was done over the weekend and I have no idea what they exactly did. I will find out to gather more data.
Thank you,
Jake
Jake Diamond
on Jul 12, 2010 at 7:13:01 pm
Jeremy,
I don't know - someone else did the upgrade. Is there a way I can check?
Jake
Jeremy Garchow
on Jul 12, 2010 at 7:14:02 pm
[Jake Diamond] "I don't know - someone else did the upgrade. Is there a way I can check? "
Do another uninstall and reinstall.
Jake Diamond
on Jul 12, 2010 at 7:19:30 pm
OK, thank you!
Jake
Michael Sacci
on Jul 12, 2010 at 8:03:27 pm
I had this problem a while back, the audio not the video, with my Kona3. It was suggested that I route all the computer audio to the Kona. This stopped the crackles for me. Have not seen a negative side effect. I turn off the annoying alert sounds anyway but that is a must or else the bonk will make you jump out of your seat.
Jake Diamond
on Jul 12, 2010 at 10:34:31 pm
Thanks Michael. I tried this and it fixed it in some places, but not all. It seems pretty random.
Jake
Olivier Aubut
on Jul 13, 2010 at 1:05:57 pm
Hi guys
I have the same problem with fcp 7.0.2, osx 10.6.3 and kona LHi 8.0 on an octo, 16GB Ram. It's a brand new system so the kona never was on a previous version. Everything is up to date.
I tried the 8.0 NDD but it still has the same problem.
I will try to downgrade the control panel and the firmware. Hope it'll help.
Please let me know if you have any other suggestions.
Olivier
Edit: ooh and I tried Michael's suggestion to route the system audio to the kona. It did not fix the problem.
Michael Gossen
on Jul 13, 2010 at 5:32:30 pm
What is your "Ref In" set to? Do you have a stable BB or tri-level sync?
Michael Gossen
Helium Digital Media
Olivier Aubut
on Jul 13, 2010 at 5:39:28 pm
Thanks Michael
My Genlock is set to Freerun. I don't have a deck, I mainly use the Kona for monitoring as I work with file-based XDcam.
Would a BB do the trick?
Sorry Jake for hijacking your post.
Michael Gossen
on Jul 13, 2010 at 6:21:29 pm
Hmmm... Freerun should be fine. You shouldn't need a BB signal for just monitoring. No deck connected? Any SDI input?
Michael Gossen
Olivier Aubut
on Jul 13, 2010 at 6:33:56 pm
No input at all. The monitor is connected component and the audio directly connected to the speakers using AES/EBU.
I'm cutting some XDcam 1080p30 stuff and since my monitor does not have an sdi input, I have to monitor through component at 1080i29,97. I read somewhere else that the crackling might be because I'm monitoring at another res.
I might try to connect my broadcast monitor through HDMI/DVI.
Is HDMI good enough for grading?
Thanks for your help.
Olivier
Jeremy Garchow
on Jul 13, 2010 at 6:37:13 pm
[Olivier Aubut] "I'm cutting some XDcam 1080p30 stuff and since my monitor does not have an sdi input, I have to monitor through component at 1080i29,97. I read somewhere else that the crackling might be because I'm monitoring at another res. "
What 'res' are you monitoring?
1080p30 XDcam and 1080i29.97 are really the same thing, that is your 1080p XDcam can be monitored @ 1080psf29.97 (which is the 1080i setting on the Kona @ 29.97 fps).
Jeremy
Michael Gossen
on Jul 13, 2010 at 6:43:20 pm
What speakers do you have? Have you tried the analog audio outs?
Michael Gossen
Olivier Aubut
on Jul 13, 2010 at 6:53:08 pm
Thanks Jeremy - I wasn't aware of this. So I bet using an HDMI won't make a difference.
Michael - The analog audio had the same problem. I have Roland DS-5 speakers.
Thanks for your suggestions guys
Jeremy Garchow
on Jul 13, 2010 at 6:54:22 pm
Is your sequence set to 16 or 24bit audio?
Jeremy
Olivier Aubut
on Jul 13, 2010 at 7:02:26 pm
24bit.
But the problem isn't only in the audio. Just like the OP, I have some thin horizontal white lines on the output video.
Jeremy Garchow
on Jul 13, 2010 at 7:06:48 pm
[Olivier Aubut] "24bit.
But the problem isn't only in the audio. "
ANd your footage is 16bit I take it?
[Olivier Aubut] "Just like the OP, I have some thin horizontal white lines on the output video."
What else do you have in the ay of PCI cards in your mac? This sounds like either a configuration issue or mismatched settings.
Olivier Aubut
on Jul 13, 2010 at 7:13:41 pm
I have a mix of 16 and 24bit audio in a 24bit sequence.
The LHi is in slot 2 and I have a Caldigit PCI-E card in slot 4.
Jeremy Garchow
on Jul 13, 2010 at 7:15:57 pm
I'd put the raid on slot 2 and Kona in slot 3.
The mixed audio is probably causing your crackles as well.
Jeremy
Olivier Aubut
on Jul 13, 2010 at 7:28:49 pm
Thanks - I'll give it a try.
I Changed the sequence bit depth and the crackling is happening on both 16 and 24bit. So I doubt that this is the problem.
Hopefully the card order will help.
I'll post the results.
Thanks Jeremy
Jeremy Garchow
on Jul 13, 2010 at 7:33:28 pm
[Olivier Aubut] "I Changed the sequence bit depth and the crackling is happening on both 16 and 24bit. So I doubt that this is the problem. "
But that still leaves you with mixed audio sources.
Olivier Aubut
on Jul 13, 2010 at 7:46:27 pm
Sorry, I wasn't clear at all.
I tested some 16bit footage on a 16bit sequence and some 24bit footage on a 24bit sequence. Audio problems on both.
Am I missing something?
Jeremy Garchow
on Jul 13, 2010 at 7:48:03 pm
[Olivier Aubut] "Am I missing something?"
No, I missed it. I get crackles sometimes if my audio isn't lined up (44.1 vs 48, 16 vs 24, etc). It has been a really long time, though. It's also troubling that you are getting video hits. Something doesn't seem like it's configured correctly.
Jeremy
Olivier Aubut
on Jul 13, 2010 at 10:07:51 pm
Well, the reorder didn't fix the problem but the downgrade seems to have done the trick.
I'm now on control panel 7.5.1 NDD and there is no more crackling or video glitches. Huzza!
I hope someone from AJA reads this.
Thanks for your help Jeremy
Olivier
Mike Weber
on Jul 13, 2010 at 11:17:33 pm
We just installed a Kona LHi last week, and were experiencing the exact same problem - random audio crackling and video hits. I followed your lead - uninstalled Kona LHi Driver 8.0, installed 7.5.1, and all is well so far - crackling and hits are gone. Thanks for sharing your solution!
Mike
Jake Diamond
on Jul 13, 2010 at 11:36:16 pm
Thanks to everyone for your help! Yes, reinstalling 7.5.1 fixed it.
AJA Sales Department
on Jul 15, 2010 at 9:56:33 pm
There is a new release for the KONA LHi. The new release version is 8.0.1. This release addresses a KONA LHi issue where some users experienced intermittent glitches in video and audio. Features and improvements are otherwise exactly the same as the version 8.0 driver.
Visit the AJA website at the following URL to obtain this version:
http://www.aja.com/support/konaNEW/kona-lhi.php
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
