Kona LHe "There is no video"
Arden Hamrick
on Jun 28, 2010 at 8:43:42 pm
I'm having a problem capturing running footage from a BetaSP through my Kona LHe.
I've checked all the connections, and the monitor hooked to the VTR displays the video flawlessly.
FCP recognizes the VTR and I can control it with the log and capture panel.
My settings are the same I've always used to capture running footage:
Device Control: AJA Kona LH: 29.97 Sony VTR A
Capture/Input: AJA Kona LH: 525 29.97 DVCpro50
Here is the problem, I can see a time code, but I am not getting video.
All drivers are current, and I'm using FCP 6.0.6
Any help would be greatly appreciated, I have commercials I need to get out!
Arden
gary adcock
Re: Kona LHe "There is no video"
on Jun 28, 2010 at 8:49:41 pm
How are you connected to the deck? Composite or component? Did you choose analog input in the kona control panel? This cannot be done from within final cut- you must configure inputs in the Aja control panel in the Applications folder.
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Technology Development
Quality Assurance Assistance
Chicago, IL
http://blogs.creativecow.net/24640
Arden Hamrick
on Jun 28, 2010 at 8:59:40 pm
Thanks for the quick reply!
I just needed to set it to analog, and I'm connected through composite.
Problem solved, thanks so much.
Neri Perdigon
on Sep 23, 2010 at 4:01:29 am
Hi I'm having problem with my new MAC PRO FCP 7.0 with AJA Kona Lhe v.8 driver. I am editing in FCP 7 at DV NTSC but i do not have a video monitor output. What will be the settings in AJA KONA LHe control panel. thanks
Neri Perdigon
ZOETV - Manila
Neri Perdigon
on Sep 23, 2010 at 4:51:31 am
Hi Gary,
Can you help me please! I have a project in FCP 7.0 with AJA KONA LHe but i don't have Video Monitor Output. What will be the correct settings in AJA Control Panel? I'm editing in NTSC DV only. Thanks
Neri
gary adcock
on Sep 23, 2010 at 10:05:55 am
[Neri Perdigon] "AJA KONA LHe but i don't have Video Monitor Output. "
you should be using the correct Setup in FCP first
it should say -
AJA KONA LHE- NTSC 8 Bit to DV and make sure that you go to View > External Video> Show all frames
and you should be able to see your video out.
gary adcock
Studio37
Chicago, IL
Neri Perdigon
on Sep 23, 2010 at 10:20:49 am
Thanks Gary,
What do you mean by settings in FCP? Is it the audio and video settings video playback or the sequence preset? Because there is no AJA KONA LHE- NTSC 8 Bit to DV in video playback or sequence preset.
Neri
gary adcock
on Sep 24, 2010 at 3:51:37 pm
[Neri Perdigon] "What do you mean by settings in FCP? "
You need to use the FCP EASY SETUP with the settings I mentioned.
if they are not available to you the drivers are not properly installed
gary adcock
Studio37
Chicago, IL
Neri Perdigon
on Sep 27, 2010 at 2:35:48 am
Thanks Gary for the reply. i've tried what you said but it seems my AJA KONA LHe is not responding at any settings, video input and output.
