Install older version of quicktime
Matt Kerstein
on Jun 11, 2010 at 2:36:05 am
Having export issues after a quicktime update. System that works properly is at OSX 10.4.11 and Quicktime ver 7.6.4. with AJA KONA LHe ver 6.0.1
When I export from other two systems running OSX 10.5.8 quicktime 7.6.6 I get vertical lines in quicktime exports. How to a back track to the those previous versions?
Thank You
Aloha & Mahalo from Maui
Jeremy Garchow
Re: Install older version of quicktime
on Jun 11, 2010 at 2:17:17 pm
More info, please. What format?
Matt Kerstein
on Jun 11, 2010 at 5:02:03 pm
Making HDV 720p30 from DVCPro 720p 59.94
System with older version OS and QT version works fine. Other 2 with updates do not?
Jeremy Garchow
on Jun 11, 2010 at 5:15:41 pm
How are you 'making' this?
Matt Kerstein
on Jun 11, 2010 at 5:40:33 pm
Export from timeline Custom QuickTime movie
Jeremy Garchow
on Jun 11, 2010 at 6:39:34 pm
[Matt Kerstein] "Export from timeline Custom QuickTime movie "
I'd would export a reference movie, and do this process in Compressor. Much better quality, or use your Kona card (you do have a Kona card, right, this is the Kona forum after all) to capture in real time to DVCPro HD.
Jeremy
Matt Kerstein
on Jun 11, 2010 at 6:50:36 pm
The vertical lines that appear is very subtle. almost looks like vertical interlace lines..bit its there. Work around for now is use to use compressor..but would like to keep previous workflow for the export. This codec (HDV 720P30) is what we have to use to playout of our Omneon for broadcast.
Jeremy Garchow
on Jun 11, 2010 at 6:55:43 pm
Quicktime Conversion out of FCP is no good. Stick with Compressor.
And I think I misunderstood, you are going from DVCPro HD to HDV.
Can you use XDcam? if so, you can export using XDcam to an Omneon qualified MXF right to FCP using this:
http://mxf4mac.com/mxf-gc-export
Jeremy
