Kona LHI and Broadcast Monitor
Eddie Stein
on Jun 2, 2010 at 1:20:30 pm
Thank you Creative Cow members in advance for reading/responding to my post.
Currently I have a MacPro 2.26ghz, Aja Kona LHI breakout box and a TV Logic LVM-172W Broadcast monitor setup. The broadcast monitor is hooked up to the AJA breakout box via HDMI converted to DVI. My problem is that I am unable to calibrate the broadcast monitor correctly. I am calibrating using brightness, contrast, bluegun, color and hue and I believe I understand to proper way to use those controls.
I tried using smpte bars from Final Cut Pro, and I tried exporting bars from Avid Express Pro and imported them into FCP for output to the broadcast monitor. For some reason, no matter how much I adjust the contrast or brightness, I can't get the three smpte pluge bars to separate. They all stay the same black color. So the picture looks somewhat muddy. This is a brand new monitor. Is there something else I can do to properly calibrate this monitor?
Thank you so much for your thoughts.
Eddie
Thank you very much.
Jeremy Garchow
Re: Kona LHI and Broadcast Monitor
on Jun 2, 2010 at 6:15:21 pm
[Eddie Stein] "he broadcast monitor is hooked up to the AJA breakout box via HDMI converted to DVI. "
Why not HDSDI?
Eddie Stein
on Jun 2, 2010 at 8:15:36 pm
The wrong cable was ordered but I Thought HDMI was OK. Is it not OK?
Jeremy Garchow
on Jun 2, 2010 at 8:17:15 pm
HDMI is ok, but perhaps the DVI connection on the monitor isn't. Try hooking it up HDSDI and see if it works.
Eddie Stein
on Jun 2, 2010 at 8:21:04 pm
I will. Thanks.
Eddie Stein
on Jun 11, 2010 at 12:02:10 pm
switching to HD SDI did the trick. Thanks.
