What is the difference betrween Kona LHI or Kona 3?
Rainer Wirth
on May 21, 2010 at 12:30:46 pm
I'm thinking of setting up a new system.
What do I need?
I need motion and coulor monitoring SD and HD. I need FCP monitoring in HD and SD SdI (one channel)
What card should I go for ?
thanks
Rainer
walter biscardi
Re: What is the difference betrween Kona LHI or Kona 3?
on May 21, 2010 at 12:37:30 pm
This has been discussed multiple times in this forum and if you do a Search you'll find more answers. Short story.
LHi: cannot do RED workflow, cannot do 2k workflow.
DOES have Analog I/O and HDMI I/O
Kona 3: Can work in pretty much any workflow.
DOES NOT have Analog inputs. All digital inputs and the only analog are the component and RCA audio outputs.
Both cards do Up / Down / Cross Conversion.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media
"Foul Water, Fiery Serpent" featuring Sigourney Weaver coming soon.
Blog Twitter Facebook
Rainer Wirth
on May 21, 2010 at 12:54:38 pm
Thanks Walter,
this helps
Rainer
Michael Sacci
on May 22, 2010 at 2:21:19 am
FWIW, Kona 3 does not have RCA audio out unless you also get the breakout box.
