EX3 (in camera) Downconvert vs Kona LHi Downconvert
Martin Phillips
on May 8, 2010 at 8:10:56 am
Just wondered about the perceived wisdom here. Got a 2 cam conference video shot on DSR450 and EX3 to go to SD DVD. Want to edit on SD timeline in FCP.
Should I downconvert using the camera and digitise into the Kona LHI via SDI, or should I come HD SDI out of the camera and let the Kona do the downconvert. Just wondered whether anyone has found one particular way that works best?
Richard Cooper
Re: EX3 (in camera) Downconvert vs Kona LHi Downconvert
on May 8, 2010 at 8:05:10 pm
Hello Martin,
I work with bot the EX cam and the Kona 3 and my first inclination would be to let the Kona do the down-convert. I have never tested this work flow (down-convert on input) but this would be the first thing I would try. Try a small test (both ways) and see which one looks better, my money would be on the Kona.
One caution... I have captured HD/SDI direct from my EX camera only one time, just recently, and it was only then that I found that even though I shot 1080/24p(23.98) on my EX the HD/SDI output was 29.97! I could not find an option to output 23.98. But unless you are shooting @24 this should not be an issue for you.
I am sure once you try about 30 seconds of both work flows you will be able to make a decision on the best for your purposes.
Good Luck. Let us know what you find with your test.
Richard Cooper
FrostLine Productions, LLC
Anchorage, Alaska
http://www.frostlineproductions.com
Richard Cooper
on May 15, 2010 at 6:31:37 pm
Hi Martin, So what did you find out with the work-flow experiment?
Which works better?
Richard Cooper
Anchorage, Alaska
Martin Phillips
on May 18, 2010 at 8:55:23 am
Sorry - only managed to do the experiment for real yesterday. I must admit that I was pretty hard-pressed to notice the difference between either of them. They both came out staggeringly well, which I was really pleased about. When compared to the DSR450 (with J21 lens) shots I think they actually had a slight edge over them.
Admittedly this was in a conference environment, would be good to experiment with outdoor shots ...... a job for another day!
Cheers, Martin.
