Capturing Key and Fill Kona LHi Final cut Pro 5.1
Andy Lynch
on Apr 28, 2010 at 11:13:02 pm
I am trying to figure out if it is possible to capture 1080i Key and Fill, simultaneously with a KONA LHi. I am running Final Cut Pro 5.1, and trying to capture the key and fill from an Avid HD Dekocast machine. I imagine that I would take the fill normally, through the input BNC on the back of the card. Would one of the other inputs on the pigtail be able to capture the key. Or would it be possible to take the key as component video at the same time?
Andy
Jeremy Garchow
Re: Capturing Key and Fill Kona LHi Final cut Pro 5.1
on Apr 29, 2010 at 11:03:11 am
Unfortunately, no. You'd have to combine the streams later (capture twice) or combine in a mixer.
