dvcpro hd 1080p25 gone?
Joel Arvidsson
on Apr 6, 2010 at 5:38:27 am
Hi I cant find the dvcpro hd 1080p25 preset inside since I upgraded to fcp7. I have upgraded the kona drivers to 7.51 also.
Its a bit of panic. Any suggestions?
joelarvidsson@gmail.com
Joel Arvidsson
Re: dvcpro hd 1080p25 gone?
on Apr 6, 2010 at 5:44:34 am
/Library/Application Support/Final Cut Pro System Support/Custom Settings/Kona LH Easy Setups:
03/17/2010 20:03 - AJA KONA LH- 1080i 25 10 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080i 25 8 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080i 25 Apple ProRes 422 (HQ).fcpre
03/17/2010 20:03 - AJA KONA LH- 1080i 25 Apple ProRes 422 (LT).fcpre
03/17/2010 20:03 - AJA KONA LH- 1080i 25 Apple ProRes 422 (Proxy).fcpre
03/17/2010 20:03 - AJA KONA LH- 1080i 25 Apple ProRes 422.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080i 29.97 10 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080i 29.97 8 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080i 29.97 Apple ProRes 422 (HQ).fcpre
03/17/2010 20:03 - AJA KONA LH- 1080i 29.97 Apple ProRes 422 (LT).fcpre
03/17/2010 20:03 - AJA KONA LH- 1080i 29.97 Apple ProRes 422 (Proxy).fcpre
03/17/2010 20:03 - AJA KONA LH- 1080i 29.97 Apple ProRes 422.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 23.98 10 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 23.98 8 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 23.98 Apple ProRes 422 (HQ).fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 23.98 Apple ProRes 422 (LT).fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 23.98 Apple ProRes 422 (Proxy).fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 23.98 Apple ProRes 422.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 50 10 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 50 8 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 50 Apple ProRes 422 (HQ).fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 50 Apple ProRes 422 (LT).fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 50 Apple ProRes 422 (Proxy).fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 50 Apple ProRes 422.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 59.94 10 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 59.94 8 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 59.94 Apple ProRes 422 (HQ).fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 59.94 Apple ProRes 422 (LT).fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 59.94 Apple ProRes 422 (Proxy).fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 59.94 Apple ProRes 422.fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC 10 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC 8 Bit to DV.fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC 8 Bit to DVCPro50.fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC 8 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC Apple ProRes 422 (HQ).fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC Apple ProRes 422 (LT).fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC Apple ProRes 422 (Proxy).fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC Apple ProRes 422.fcpre
03/17/2010 20:03 - AJA KONA LH- PAL 10 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- PAL 8 Bit to DV.fcpre
03/17/2010 20:03 - AJA KONA LH- PAL 8 Bit to DVCPro.fcpre
03/17/2010 20:03 - AJA KONA LH- PAL 8 Bit to DVCPro50.fcpre
03/17/2010 20:03 - AJA KONA LH- PAL 8 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- PAL Apple ProRes 422 (HQ).fcpre
03/17/2010 20:03 - AJA KONA LH- PAL Apple ProRes 422 (LT).fcpre
03/17/2010 20:03 - AJA KONA LH- PAL Apple ProRes 422 (Proxy).fcpre
03/17/2010 20:03 - AJA KONA LH- PAL Apple ProRes 422.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080p23.98 10 Bit Uncompressed VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080p23.98 8 Bit Uncompressed VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080p23.98 Apple ProRes 422 (HQ) VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080p23.98 Apple ProRes 422 (LT) VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080p23.98 Apple ProRes 422 (Proxy) VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080p23.98 Apple ProRes 422 VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 23.98 10 Bit VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 23.98 8 Bit VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 23.98 Apple ProRes 422 (HQ) VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 23.98 Apple ProRes 422 (LT) VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 23.98 Apple ProRes 422 (Proxy) VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 23.98 Apple ProRes 422 VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 10 Bit VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 8 Bit VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 Apple ProRes 422 (HQ) VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 Apple ProRes 422 (LT) VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 Apple ProRes 422 (Proxy) VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 Apple ProRes 422 VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080p23.98 DVCProHD VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 23.98 DVCPro HD VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 DVCPro HD VFR.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 24 10 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 24 8 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 24 Apple ProRes 422 (HQ).fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 24 Apple ProRes 422 (LT).fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 24 Apple ProRes 422 (Proxy).fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 24 Apple ProRes 422.fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC 23.98 10 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC 23.98 8 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC 23.98 Apple ProRes 422 (HQ).fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC 23.98 Apple ProRes 422 (LT).fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC 23.98 Apple ProRes 422 (Proxy).fcpre
03/17/2010 20:03 - AJA KONA LH- NTSC 23.98 Apple ProRes 422.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 23.98 DVCPro HD.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080psf 24 DVCPro HD.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 10 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 8 Bit Uncompressed.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 Apple ProRes 422 (HQ).fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 Apple ProRes 422 (LT).fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 Apple ProRes 422 (Proxy).fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 Apple ProRes 422.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080i 25 DVCPro HD.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 25 DVCPro HD.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 50 DVCPro HD.fcpre
03/17/2010 20:03 - AJA KONA LH- 1080i 29.97 DVCPro HD.fcpre
03/17/2010 20:03 - AJA KONA LH- 720p 59.94 DVCPro HD.fcpre
03/17/2010 20:03 - AJA KONA LH- HDV Edit to Tape 1080i50.fcpre
03/17/2010 20:03 - AJA KONA LH- HDV Edit to Tape 1080i60.fcpre
03/17/2010 20:03 - AJA KONA LH- HDV Edit to Tape 720p30.fcpre
03/17/2010 20:03 - AJA KONA LH- HDV Edit to Tape Apple Intermediate Codec
gary adcock
on Apr 6, 2010 at 11:02:58 am
[Joel Arvidsson] "Hi I cant find the dvcpro hd 1080p25 preset inside since I upgraded to fcp7."
thats because it is called 25i based on the format as delivered.
The transport stream is always interlaced.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://blogs.creativecow.net/24640
Jeremy Garchow
on Apr 6, 2010 at 6:54:39 pm
You just need to install the correct easy setup in the drivers. You can uncheck the driver and check the easy setup. Here's a picture:
Jeremy
