Sync issue with Kona LHe
Matthew Hannam
on Apr 1, 2010 at 3:16:54 pm
Hey,
I have a quad core 2.66 from a few years ago with a Kona LHe. Running FCP 7 with the 7.5.1 update for my Kona control panel.
In the last week, for some reason the sync has become totally unreliable on my monitors.
Has something changed? I should still have the playback frame offset set to 0 correct?
Ted Joyce
Re: Sync issue with Kona LHe
on Apr 1, 2010 at 6:58:00 pm
I've a Kona3 w/ FC7 all up to date & notice the same thing a few weeks ago. Though my files are 1080psf/23.97, if I set FC's video playback at that same frame rate the sync is weird. The SDI output esp. has early audio. It seems much better if I set it to 29.7 frame rate though.
