adjusting 5.1 surround volume
Bob Zelin
on Mar 13, 2010 at 4:08:51 pm
Hi -
probably wrong forum, but Kona users are the hi end today.
In an edit suite (not sound mix room), when you want to adjust your overall volume, how are you controlling the volume of your 5.1 monitoring system for audio ? Is there an equivelent to the Mackie Big Knob for 5.1 ?
Bob Zelin
Bob Zelin
Re: adjusting 5.1 surround volume
on Mar 14, 2010 at 4:14:32 pm
Thanks Warren, but it's discontinued. I was shocked to see the hi prices of many of these products, but I found the SPL unit for under $1000 -
The Grace Audio 5.1 volume knob is over $5000 !
Bob Zelin
Warren Eig
on Mar 14, 2010 at 6:57:48 pm
I know it's discontinued, but great way to go if you can find one used.
Have a great weekend, Bob.
Warren
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.babyboompictures.com
http://www.babyboompictures.com/BabyBoomPictures/AFX.html
http://www.babyboompictures.com/BabyBoomPictures/KnitWits_Movie.html
http://www.imdb.com/name/nm0251670/
EDITING REEL: http://www.babyboompictures.com/BabyBoomPictures/Editing_Reel.html
TITLE DESIGN: http://www.babyboompictures.com/BabyBoomPictures/Titles_Reel.html
James Reid
on Mar 16, 2010 at 3:40:27 am
If.. you are using a receiver with 6 to 8 direct audio inputs,
I have used my M-Audio ProFire 610 ($360-$400). Use a combo cable with 8 TS to RCA.
Now that I have a new receiver that omits those, I use HDMI
from my MXO2 mini to the receiver, also 8 channels.
With the latest 1.9 software the MXO2 audio also shows up
as an audio selection in the general sound prefs in OS X.
Select the output channels/layout in the Audio Midi Setup app.
nick hasson
on Mar 16, 2010 at 5:15:18 pm
Bob,
This is what I am using for 5.1.
http://www.studio-tech.com/ProductPage-M78M79.htm
Nick Hasson
EDIT - Smoke artist
http://www.niceedits.com
Bob Zelin
on Mar 17, 2010 at 12:39:01 am
Hi Nick -
that was the first thing I saw when I started to google everything.
How much was it - was it under $3000 ? I am going to use it in a setup in LA.
Bob Zelin
nick hasson
on Mar 17, 2010 at 12:45:11 am
I wanna say it was 1600. I've had it for a few years now with no problems.
Nick Hasson
EDIT - Smoke artist
Phil Erney
on Mar 29, 2010 at 8:33:03 pm
Grace is expensive. Dangerous Music also mades a 5.1 system. I was looking at Coleman Audio SR5.1 mkII. (Didn't end up getting it). If you don't need suming it looks like it could do the trick for around 1,000.
Some monitoring systems have this built in. The Digital JBL's maybe with the remote (they mute/control volume from software, remote and speaker face). I think Blue Sky as well.
On the low end (I have done this to test output on consumer QC setups) you can take 50 ohm BNC AES outputs and go directly into Discreet Digital RCA ins of consumer amplifiers.
You could also program digital mixers (like the Yamaha 01v96 with additional routing outputs) to control it. Gets pricy.
-Phil
Please do post your solution.
