Lhi HDMI in not working after 7.5 driver install
David de Vos
on Mar 3, 2010 at 3:19:15 am
Can't get a signal on the LHi HDMI in after installing the 7.5 NDD driver and updating the fimware. (I did get a signal before, no problem) I've unistalled the 7.5 NDD driver and reinstalled 7.1, but it's still not working. It asks me to update the firmware on startup, which leads me to believe it's defaulted to the older firmware, but not sure.
Any thoughts?
Thanks.
Dave
Jeremy Garchow
Re: Lhi HDMI in not working after 7.5 driver install
on Mar 3, 2010 at 3:22:21 am
Did you uninstall before installing 7.5?
David de Vos
on Mar 3, 2010 at 3:23:27 am
Yep. Sure did.
David de Vos
on Mar 3, 2010 at 3:24:58 am
One other note. It carries the audio, but not the video. Tried 3 different cables, hooked it up directly my HDTV to make sure the signal coming in was working, etc. It's all good. Narrowed it down to the Kona. Only thing I changed was the driver, thus my suspicion...
Jeremy Garchow
on Mar 3, 2010 at 3:28:51 am
I take it audio is coming in via HDMI?
Have a look at your HDMI tab in the control panel with fcp open (must be able
to see control panel when fcp is active). Is HDMI even selected as the input?
