Kona 3 Defaults
Arthur Aldrich
Kona 3 Defaults
on Feb 23, 2010 at 4:03:03 pm
Anyone know if there is a way to set the default audio input on Kona3 with Kbox to be the xlr input?
It looks like it defaults to embedded audio.
I know if I create a preset in Kona Control, it will load in, but I need this setting to come up at boot up.
TIA,
Art Aldrich
OTEK TV
Leader, NJFCPUG
http://www.njfcpug.org
http://www.otek.tv
Jeremy Garchow
Re: Kona 3 Defaults
on Feb 23, 2010 at 5:35:46 pm
If you set it to AES it doesn't stick?
If this is so, trash your Control Panel prefs, then make sure your permissions are set properly.
Jeremy
gary adcock
Re: Kona 3 Defaults
on Feb 23, 2010 at 5:43:49 pm
[Arthur Aldrich] "Anyone know if there is a way to set the default audio input on Kona3 with Kbox to be the xlr input? "
art
those are AES connections not Analog XLR's
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://blogs.creativecow.net/24640
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Arthur Aldrich
Re: Kona 3 Defaults
on Feb 23, 2010 at 7:03:43 pm
Thanks Gary,
I realize that these connectors are digital. I am using ADA4 to get analog audio into Kona. It travels on the XLR inputs.
With some capture cards, audio input is chosen via FCP in the capture preset editor. There are no options to choose which input via FCP for the Kona. The setting on the Kona CP does not hold after a restart.
Art Aldrich
OTEK TV
Leader, NJFCPUG
http://www.otek.tv
Arthur Aldrich
Re: Kona 3 Defaults
on Feb 23, 2010 at 7:11:49 pm
AJA Support has shed some light on my problem.
This Kona system is in a college. I have the students log in as a non-admin user.
The control pannel will not store the last used state if the logged in user is not an admin.
So either i figure out a way to override the default settings in the system library or have the students load a preset before each session.
Art Aldrich
OTEK TV
Leader, NJFCPUG
http://www.otek.tv
