Kona DownConvert Issue
Andrew Saliga
on Feb 19, 2010 at 10:39:16 pm
In a pinch and searching.
Can a Kona 3 downconvert ProRes422HQ 1920x1080p 23.98 to SD? Having issues.
-Andrew Saliga
Steelehouse Productions
http://www.steelehouse.com (undergoing a much-needed redesign)
http://www.vimeo.com/steelehouse
Michael Sacci
Re: Kona DownConvert Issue
on Feb 20, 2010 at 12:05:30 am
yes but very few things that are SD can handle true 23.98 so you normally go to 525 @ 29.97 with a pull down added.
Andrew Saliga
on Feb 20, 2010 at 12:17:29 am
Sorry, was in rush mode. For some reason the ad agency told all local stations that the spots were ready before they were even approved.
Is there a specific pulldown I should select? 3:2:3:2?
-Andrew Saliga
Andrew Saliga
on Feb 20, 2010 at 12:20:02 am
I have the Kona set to 2:3:23 I see. Is there something I'm missing? I have siganl from Kona to deck to monitor, but I can't seem to get it right to run FCP through. (test signals from Kona control panel work)
Edit was shot film, was transferred to ProRes422HQ at 1920x1080, progressive and 23.98. Running it out to Beta.
-Andrew Saliga
Jeremy Garchow
on Feb 20, 2010 at 2:03:18 am
You have to put your easy setup in to 1080 psf 23.98, then use the secondary output on the control panel for your output device. For instance, if you are using SDI2 that is going to your Sd deck, then right click on the SDI2 triangle in the control panel and change it to 'secondary' then right click again and choose 525i.
Jeremy
Bob Zelin
on Feb 20, 2010 at 2:34:59 pm
go to Audio/Video settings, playback, and select something that is a 29.97 output, not 23.98 (there is no 23.98 standard def downconvert). Then once you are at 1080i/29.97 playback output in your Audio/Video settings in FCP, THEN the control panel FORMAT tab can be set on secondary to 525, and it will downconvert to a true standard def VTR format.
Bob Zelin
Andrew Saliga
on Feb 22, 2010 at 5:19:30 pm
Thanks guys.
I wasn't able to get it to work when I needed it the most, but today when I casually try your suggested setup I have no problems. Curse of the output day I guess.
So to recap, footage was shot on film, transferred to ProRes422 HQ 1920x1080p at 23.98fps. FCP sequences were set to be the same as this source. I set my easy setup to 1080psf23.98 ProRes HQ. Adjusted my deck control to a 29.97 deck since I was running to Beta, and me secondary output in the Kona Control Panel was set to 525i29.97.
Also Bob, you'd proud to know that we bought the AJA black burst generator you preach about. :)
-Andrew Saliga
