Kona LHe 720p23.98
Richard Lowe
Kona LHe 720p23.98
on Feb 9, 2010 at 12:01:30 am
Hey everyone,
We shot a short documentary with the HVX-200. It was shot at 720p23.98. I set up FCP with the Easy Setup and everything works fine within FCP, but I'd like to be able to view it on my external Apple monitor which is connected via the Kona LHe.
What should I be looking for?
Shane Ross
Re: Kona LHe 720p23.98
on Feb 9, 2010 at 2:02:55 am
AJA Kona 720p60 DVCPRO HD 8-bit. DVCPRO HD is a 720p60 compressor...so no matter what the frame rate, that is the viewing option you choose.
Shane
Jeremy Garchow
on Feb 9, 2010 at 3:23:40 am
Choose the dvcpro HD 720p 23.98 VFR easy setup.
Shane Ross
on Feb 9, 2010 at 5:03:25 am
Or what he said. More than one way to skin a cat.
My way allows the footage to play properly on a monitor that might have issues with 23.98 monitoring. Not all HD monitors handle that format well.
Shane
Jeremy Garchow
on Feb 9, 2010 at 2:04:15 pm
You can't watch 720 at 23.98.
Both ways are exactly the same. Choosing the vfr easy setup sets th video output to 59.94. Of you choose the 720p23.98 easy setup without the vfr, you won't get a picture.
Jeremy
