aja Kona3 desync issue at unrendered transitions
ayman abdel-basset
on Feb 4, 2010 at 5:17:23 pm
Hi
fcp7
with aja kona3 the problem when i add any text with transition and play the segment in unlimited real time.. the video on the out broadcast screen becomes in desync..But plays fine in the mac monitor..
When the segment render..it plays fine..
Does anyone had this issue before?
Best regards
A
Jeremy Garchow
Re: aja Kona3 desync issue at unrendered transitions
on Feb 4, 2010 at 8:40:53 pm
[ayman abdel-basset] "Does anyone had this issue before?"
Unlimited rt will do that. FCP isn't fast enough to render the transition and send it out to video in real time.
You must render the orange.
Jeremy
ayman abdel-basset
on Feb 5, 2010 at 5:01:44 pm
it is not transition issue!
it is matter of transitions only applied on any layer over the V1 like text..
to render it and view it! it will be slow work because it is sooo many lower thirds applied and the producer wanna check them roughly quickly!
Btw
I'll check if this happens with LHE or no.. i don't remember if i faced this problem with it or no..
A
Jeremy Garchow
on Feb 5, 2010 at 5:05:02 pm
[ayman abdel-basset] "it is not transition issue!"
Yes it is. The cross dissolve does not preserve the alpha. you must do overlapping opacity fades.
Jeremy
