LHi 525i2997 HDMI output
ann johnson
on Jan 25, 2010 at 8:48:43 pm
This might be a complete beginner question, but I couldn't find an answer in the forums, so I thought I'd ask it. I have an uncompressed 8-bit 720x486 sequence, and an AJA Kona LHi card using the HDMI output. I have my video playback setting set to AJA Kona 525i29.97 8 Bit (720 x 486). Nothing plays out of my Panasonic TH-42PH11 Plasma monitor with this setting. If I change the Video Playback setting to 1080i/29.97, it plays back but the color shifts on the monitor from when I hit play and when it's just standing on a frame. I'm not sure if it's because it's because it's upconverting or what, but I imagine that there IS a way to playback in SD through the HDMI cable. When I go into the AJA control panel and have the test pattern set to color bars, I don't see any when I have the output set to 525i2997. Could someone please help me out?
Ann
Shane Ross
Re: LHi 525i2997 HDMI output
on Jan 26, 2010 at 12:54:28 am
HDMI only works with HD footage, as far as I know. That is part of the name... High-Definition Multimedia Interface. This doesn't work with SD.
I dunno what to say about the color shift...I don't use that output option.
Shane
Jeremy Garchow
on Jan 26, 2010 at 3:53:46 am
Make sure your HDMI output is set to HDMI and not DVI.
