KONA LHe Crashes FCP Log & Capture
Jeffrey Lonigro
on Jan 22, 2010 at 5:57:15 pm
I am on a MacPro 8core, 10.6.2, Aja 7.1 drivers, and FCP 6.0.6.
When I try to log & capture I get a spinning beach ball usually indefinitely or sometimes followed by a crash and once with a kernel panic. FCP seems to get hung up even if you open audio video settings and start changing capture presets. We have uninstalled and re-installed the AJA drivers. That helped for a day and a half and then the problem came back.
Jeremy Garchow
Re: KONA LHe Crashes FCP Log & Capture
on Jan 22, 2010 at 6:49:38 pm
How are your PCIe slots arranged?
Jeffrey Lonigro
on Jan 22, 2010 at 7:27:36 pm
As per AJA they told us to put the LHe into slot 2.
Jeremy Garchow
on Jan 22, 2010 at 7:30:17 pm
Do you have any other PCIe cards in there besides the graphics card?
Jeffrey Lonigro
on Jan 22, 2010 at 7:53:44 pm
no
Jeremy Garchow
on Jan 22, 2010 at 8:44:01 pm
Have you trashed QT prefs? Do you have QT7 installed?
Jeffrey Lonigro
on Jan 22, 2010 at 9:30:21 pm
I do have Quicktime 7 installed
Jeremy Garchow
on Jan 22, 2010 at 9:34:03 pm
have you trashed those QT preferences?
Jeffrey Lonigro
on Jan 22, 2010 at 10:09:09 pm
No I haven't yet. Are you talking Quicktime 7 prefs only not X?
Jeremy Garchow
on Jan 22, 2010 at 10:10:48 pm
Both if you have them.
Eric Sternberger
on Jan 26, 2010 at 9:53:22 am
I wouldn´t try running 6.06 on Snow in the first place, but you probably got a new machine with Snow installed on it, right?
Jeffrey Lonigro
on Jan 26, 2010 at 1:01:06 pm
Yes the machine came with SL. We contacted Apple about running Leopard and they said they don't recommend it but sent a Leopard install disc to try. That turned into blue screen of death boot problems so we wiped the drive and installed SL. Everything has been fine accept for this issue.
Eric Sternberger
on Jan 23, 2010 at 11:08:11 am
I got this with the LHe and the 7.1 driver on a G5-Machine. Sometimes freezed the machine even when booting up, but mostly when starting log/capture. (this is on a absolutly clean install)
I deinstalled the driver and went back to 6.5 - no problems anymore...
Jeffrey Lonigro
on Jan 24, 2010 at 3:18:58 pm
I am running Snow Leopard so I don't think I can dial back to 6.5 drivers. We tried running this machine with Leopard and that was a disaster. These machines like SL. I trashed the quicktime prefs but won't get to try it out until Monday.
Jeffrey Lonigro
on Jan 25, 2010 at 9:07:48 pm
I trashed the quicktime prefs and this did not fix the problem. AJA sent a new card to try out. We will put that in tomorrow. Seems like a driver issue to me, since the card worked great in the previous system on Leopard.
Jeffrey Lonigro
on Jan 31, 2010 at 4:23:15 am
Any other thoughts on this problem?
