LHi 720p60 to 1080i59.94
Dave Flores
on Jan 20, 2010 at 4:57:52 am
I'm stumped.
I had this setup successfully running two weeks ago. The recording deck is the HVR-1500a and it accepts the HD-SDI video signal and yet when playing back I get a frozen frame. Audio from the SDI is running with no issues.
Here's the A/V settings I had saved as an Easy Setup in FCP:
NOTE: Manual suggests outputting at 10bit but it makes no difference.
Here's how the AJA Control Panel was set-up:
NOTE: 720p (Primary) was what worked before even though 1080i (Secondary) is what the AJA support suggested.
I've re-installed the driver, I've trashed the FCP settings, I've tried just about every other combination I could think of through the AJA Control P and the FCP A/V Settings and I'm just not getting anything to playback.
Any ideas?
Jeremy Garchow
Re: LHi 720p60 to 1080i59.94
on Jan 20, 2010 at 10:46:37 pm
Leave FCP in the 720p easy setup. Then set your outgoing SDI pipe to secondary and 1080i.
Jeremy
