Lost 1080p25 monitoring through FCP7
dan graetz
on Jan 15, 2010 at 9:35:20 am
Hi all,
Since my last install of the Kona 7.1 drivers I've lost the 1080p25 Playback output option inside of Audio/Video Settings. The 1080p25 option is available in the Kona control panel and there's also an Easy Setup for it. But when you apply the Easy Setup it says:
'Unable to locate the following external devices:
AJA Kona 1080p25 10 bit (1920x1080).'
I've tried reinstalling the drivers (with the relevant Easy Setups selected in the installer) but it's still the same.
I'm running a Octo Mac Pro 3.2ghz with 8gb RAM, Kona 3, REDRocket, Quad FC 4gb, FCP7.01, OSX 10.5.8
Any help would be hugely appreciated.
Cheers,
Dan
Ben Holmes
Re: Lost 1080p25 monitoring through FCP7
on Jan 15, 2010 at 10:48:44 am
To add to (and I hope not hijack) this thread, could this be related to the fact that the Easy Setup for 1080p25 (I'm using XDCAM 422 footage shot at 1080p25) the video output is set to NONE?
Manually changing the video output to 1080i25 restores my picture - but won't this be an issue when I lay this to tape? Am I losing quality on output - presumably I am. Where are the 1080p25 options?
Ben
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer
http://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
Ben Holmes
on Jan 15, 2010 at 10:51:22 am
Apologies - just noticed the reply from Gary Adcock below about using 1080i25. Don't know why it didn't come up on my search....
Still not clear why if that's the 'official' Kona setting to use for 1080p25 footage, the Easy Setup defaults to video NONE - or have my presets been corrupted/altered...?
Ben
Edit Out Ltd
Jeremy Garchow
on Jan 15, 2010 at 5:50:30 pm
If you need p (true p and not psf which many decks won't read) then you can turn in 1080p geometries in the setup tab of the kona control panel. This will turn on 1080p outputs. If you don't or it doesn't work, then use the 25i setting and you footage will get laid off psf.
Jeremy
Ben Holmes
on Jan 15, 2010 at 9:46:30 pm
Thanks Jeremy. That makes perfect sense. These edits will be laid off to HDCAM for duplication, then to various tape formats - I think it's going to around 120 broadcasters... On that basis, I imagine we would not want the true p used, but stick with psf.
Incidentally, I'm amazed by the quality of the XDCAM 422 footage. Although undoubtedly down as well to the quality of the glass used on the shoot, it really is remarkably detailed and possesses an almost 3D depth to it. Very nice...
Thanks again!
Ben
Edit Out Ltd
Jeremy Garchow
on Jan 17, 2010 at 3:05:06 pm
[Ben Holmes] "On that basis, I imagine we would not want the true p used, but stick with psf."
Yes, you are correct.
Have fun with your project!
Jeremy
dan graetz
on Jan 15, 2010 at 10:12:27 pm
thanks very much Jeremy. I felt like I was forgetting something obvious and those damn checkboxes were what it was.
really appreciate your help on this one.
cheers,
dan
Jeremy Garchow
on Jan 17, 2010 at 3:05:55 pm
[dan graetz] "really appreciate your help on this one."
No worries.
Jeremy
Joel Arvidsson
on Apr 6, 2010 at 5:04:41 am
Hi I have switch on 1080p in aja control panel but I cant find the settings for dvc pro 1080p 25fps in fcp since i upgraded to fcp 7?
joelarvidsson@gmail.com
Joel Arvidsson
on Apr 6, 2010 at 5:05:11 am
Hi I have switch on 1080p in aja control panel but I cant find the settings for dvc pro 1080p 25fps in sequence preset in fcp since i upgraded to fcp 7?
Jeremy Garchow
on Apr 6, 2010 at 5:56:57 pm
You have to install those easy setups form the driver installer. Just uncheck the driver and install the easy setups you need.
Jeremy
Jeremy Garchow
on Apr 6, 2010 at 6:53:19 pm
Here's a visual in case you need it. It might help.
Jeremy
