Can't get SD output working within FCP on Kona LHe
ajay bhadresa
on Jan 14, 2010 at 5:28:54 pm
Hi there,
I run FCP Studio 2 in conjunction with a Kona LHe and recently for some reason my SD output won't work. Within FCP I can view HD footage fine on the monitor but whenever I switch to SD footage I just get a still on my external monitor. I can playback the footage fine through AJA TV so I'm guessing it might be something to do with FCP. It is set to All frames on the video output tool so I can't understand why. Also, the Kona Control Panel is set to PAL 625 too. Any ideas?
John Fishback
Re: Can't get SD output working within FCP on Kona LHe
on Jan 14, 2010 at 10:35:37 pm
Try choosing a SD Easy Setup in FCP to view your SD material.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
