any help please!!! non-controllable!!
Eron Otcasek
on Jan 13, 2010 at 2:58:14 am
Both in FCP and in the AJA VTR Xchange Application I have no deck control thru the RS-422 cable that runs out of my AJA card (In final cut pro it says Non-controllable) in the AJA VTR Xchange Application it says: "make sure you are connected to the serial port." I am sure all my cables are tight. This is the first time I have used this Aja card(cable) cause I've just set up a new FCP station. 2.66GHz Quad-Core Intel and I have installed the G-Tech 4-Port, PCIe x4 RAID Controller into slot 4....Aja LHi card in slot 2
please any help!
walter biscardi
Re: any help please!!! non-controllable!!
on Jan 13, 2010 at 3:02:46 am
1 - what format are you trying to capture to?
2 - what VTR are you using?
3 - What Easy Setup are you using in Final Cut Pro?
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
HD Post and Production
Biscardi Creative Media
"Foul Water, Fiery Serpent" now in Post.
Creative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
Blog!
Twitter!
Eron Otcasek
on Jan 13, 2010 at 3:29:10 am
HI...thank your for your response.
I am capturing uncompressed 8bit SD
I am using a playback only sony digibeta deck J-30/SDI
the easy setup is the lhi NTSC 8-Bit Uncompressed
but may I also metion that I am having trouble with communication with just the AJA cature application (which has nothing to do with FCP)
Eron Otcasek
on Jan 13, 2010 at 6:29:52 am
I'm sorry the correct wording is "NO CUMMUNICATION"
Eron Otcasek
on Jan 13, 2010 at 6:31:22 am
communication! HAHA!
Jeremy Garchow
on Jan 13, 2010 at 2:21:51 pm
Have you installed the latest drivers and firmware?
Eron Otcasek
on Jan 13, 2010 at 4:07:30 pm
Yes all up to date
Jeremy Garchow
on Jan 13, 2010 at 4:40:12 pm
Let's keep this conversation on this thread as the old one is for the LHe.
I would swap your cards around. Kona Slot 3 and storage slot 2.
Uninstall and reinstall the drivers and make sure the firmware updater runs.
Jeremy
Eron Otcasek
on Jan 13, 2010 at 4:49:29 pm
Problem solved!!!!!! The Aja breakout cables can fit into the back of the mac upsidown, but the Aja logo should be on top!!!! Hope this will help someone else!
