problems with Kona LHe and snow leopard
Core van der Hoeven
on Jan 6, 2010 at 4:01:20 pm
Hello fellow Kona bro's,
I do have the following problem, could you please look at it and support me?
After installing the driver of the Kona LHe under snow leopard I get a panic attack and the eSATA hard drives do read and write slower.
When I uninstall the driver everything is okay again.
The driver is 7.1
Best Regards,
Core van der Hoeven
The Netherlands
Kevin Christopher
Re: problems with Kona LHe and snow leopard
on Jan 6, 2010 at 4:58:51 pm
What Raid Card are you using?
Kevin
Core van der Hoeven
on Jan 6, 2010 at 5:14:24 pm
Thanks for replaying, it's the LaCie SATA PCI-X card4E
Core
Gunter Hemeleers
on Jan 6, 2010 at 5:44:43 pm
Hello Core,
This contradicts youre previous info.
The Kona LHe is a PCIe Card, all macs have or PCI-X slots or PCIe slots.
Try to upgrade to the latest Lacie driver for the eSata card.
I know they used to have a problem with it.
Gunter Hemeleers
on Jan 6, 2010 at 5:16:30 pm
Hi Core,
Do you use the regular 7.1 driver or the NDD.
If you are using the regular driver you may want to try the NDD version.
What kind of eSATA hardware are you using?
Gunter
Core van der Hoeven
on Jan 6, 2010 at 7:02:18 pm
The lacie biggest s2s it are 5 striped hdd.
I am not shure wat driver I have installed check that in the morning.
gary adcock
on Jan 6, 2010 at 6:02:00 pm
[Core van der Hoeven] "After installing the driver of the Kona LHe under snow leopard I get a panic attack and the eSATA hard drives do read and write slower. "
I have only seen that when the you install the LHI driver by mistake.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Core van der Hoeven
on Jan 6, 2010 at 6:43:55 pm
I'm not in my studio anymore so I can't check it today.
It is possibly
thanks,
Core
