Nuke and 1080p problem?
Joel Arvidsson
on Jan 2, 2010 at 4:54:31 pm
Hi Nuke works with Aja LHe when aja is set to Aja kona 1080i25 10bit in nuke. But if I choose progressiv i get a weird image. My panasonic pro plasma support 1080p. Anybody had the same problem? 720p works in nuke.
joelarvidsson@gmail.com
Michael Sacci
Re: Nuke and 1080p problem?
on Jan 3, 2010 at 2:11:35 am
Is there a segmented frame (psf) setting available for the video out, that is what I need to use to go out 30p in NTSCland.
Joel Arvidsson
on Jan 3, 2010 at 11:48:15 am
You have
enable monitor output (X)
monitor output device: Aja
monitor output mode: example Aja kona 1080i25 10bit
In the root settings of the project you have fps but it dosent matter if i put 25 instead of 24.
gary adcock
on Jan 3, 2010 at 12:53:39 pm
[Joel Arvidsson] "Hi Nuke works with Aja LHe when aja is set to Aja kona 1080i25 10bit in nuke. But if I choose progressiv i get a weird image. My panasonic pro plasma support 1080p. Anybody had the same problem? 720p works in nuke. "
the default 1080 Broadcast format is PsF- or progressive segmented frame (interlace),
http://forums.creativecow.net/readpost/193/875880
have you loaded the 1080 P settings? True P in 1080 is rare outside of of few instances, since is is dificult to watch due to the strobing,
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
