Kona 3 vs Kona LHI
Chad Tingle
Kona 3 vs Kona LHI
on Dec 28, 2009 at 5:10:58 pm
I am in the market for an upgrade, and I've narrowed it down to the Kona 3 and it's little brother the Kona LHI. I know the Kona 3 provides some key advantages over the LHI such as Single link 4:22, Dual link 4:44 and 2k. They both up, down, and cross convert in 10 bit, so are there any other advantages to spending the extra money on the Kona 3.
Matthew Causon
Re: Kona 3 vs Kona LHI
on Dec 30, 2009 at 2:23:37 am
Hello Chad
Other than Red workflow that really comes under the 2k banner, the Kona 3 has 16 channels of embedded audio vs the Lhi's 8 channels.
http://www.aja.com/pdf/support/AJA_whitepaper_Red_workflow.pdf
The Kona 3 also has 2 SDI connections, the LHi only one (though the LHi does have HDMI, 3G and analog, so a different spec set):
http://www.aja.com/pdf/KONA_Line09.pdf
Otherwise you have it pretty covered.
Best regards
Matty Causon
Phosphor
EMEA Business Management for AJA Video Systems Inc.
Matthew Causon
on Dec 30, 2009 at 2:31:34 am
Ahh let me correct and update:
Kona 3 has Red workflow (really comes under the 2k banner):
The Kona 3 also has 2 SDI connections, the LHi only one (though the LHi does have HDMI, 3G and analog i/o, so a different spec set)
Kona 3 has 10-bit HD/SD video + key output
Kona 3 Internal HD/SD hardware based Downstream Keyer
Best regards
Matty Causon
Phosphor
