Flip HD
Matt Kerstein
Flip HD
on Dec 21, 2009 at 10:24:01 pm
Anyone have a good workflow getting flip720P30 .mp4ʻs to playback thru Kona to a monitor after converting to whatever flavor gets best results?
Aloha & Mahalo from Maui
Shane Ross
Re: Flip HD
on Dec 22, 2009 at 12:29:12 am
Convert it to PRO RES...via MPEG STREAMCLIP or Compressor... and then choose the Kona ProRes setting for the format you converted to. Works fine.
Shane
Matt Kerstein
Re: Flip HD
on Dec 22, 2009 at 2:08:53 am
Thanks Shane,
Did Pro Res via compressor but had playback issues till I realized that I needed to convert to 720P 59.94. Flip shoots 30.
gary adcock
Re: Flip HD
on Dec 23, 2009 at 2:50:09 pm
[Matt Kerstein] "Anyone have a good workflow getting flip720P30 .mp4ʻs to playback thru Kona to a monitor after converting to whatever flavor gets best results? "
I use the HDMI> HDSDI conversion to capture, it offers significantly better signal than a software conversion does.
On set I use the aja HA5 converter ( HDMI- HDSDI) or now a KiPro, works for output from the Canon DSLR's also.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Matt Kerstein
Re: Flip HD
on Dec 30, 2009 at 7:47:35 pm
Thanx for the info gary..BTW great article on Pro Res "a closer Look"
