no video monitor during playback
Nick Lammers
on Dec 16, 2009 at 3:32:54 pm
Hi all. I have a Kona LHi-RO in my MacPro with FCP 6.0.6. I am editing an XDCam EX sequence and monitoring HD through the SDI port and also SD through downconversion on the composite port. The issue is this: monitoring is fine through scrubbing, trimming, etc. but when I actually play the sequence the video (on the monitor, not in FCP) freezes and holds the frame that the playhead started on. When I stop playback the monitor is updated to the "correct" frame. I have not knowingly changed any settings since when this was working properly. Thanks for any help.
Nick Lammers
Med21, LLC
St. Louis, MO
Jeremy Garchow
Re: no video monitor during playback
on Dec 16, 2009 at 6:12:43 pm
Reset your HD easy setup in FCP and make sure your composite output is set to secondary/525i in the Kona control panel.
Jeremy
Nick Lammers
on Dec 16, 2009 at 7:22:57 pm
Thanks Jeremy. You were right - I had a mismatch in the settings. I forgot that some of the material was 720p and the outputs were set for 1080i.
Nick Lammers
Med21, LLC
St. Louis, MO
