HD > SD Downconvert Issue
Luke Dabbs
on Dec 7, 2009 at 8:08:02 pm
Hey guys,
I've seen this brought up in other threads but was wondering if anyone had found a solution.
Basically, as I'm sure some of you have noticed, when playing out a sequence from FCP (we're running v7) using the downconvert option on the AJA card, the first frame of the sequence is duped and the rest of the sequence thrown out by one frame (which also puts the video out of sync with the audio).
Has anyone managed to find a solution to this problem? Is it a firmware/driver issue, or simply a hardware fault?
