AJA Setup
Arden Hamrick
AJA Setup
on Nov 13, 2009 at 8:25:28 pm
Hello!
I just received running footage for 2010 from Kia for our advertising agency. Of course it came on Betacam, so thats where I have a problem. As I just started a few months ago, I've never set up Final Cut Pro to capture from the betacam through the AJA card. My question is, what settings do I use for capture?
My system is: BetaCamSP BVW-70, I have an AJA Converter, and A Mac OSX 10.4.11 Quad Core 8GB Ram running Final Cut Pro 6.06, any help would be greatly appreciated as I have deadlines for these commercial spots.
Arden
Arden Hamrick
Re: AJA Setup
on Nov 13, 2009 at 8:58:32 pm
Okay, I ran easy setup on FCP, but I still don't have video, what could be the problem?
Bob Zelin
Re: AJA Setup
on Nov 14, 2009 at 12:54:36 am
you are not even saying what AJA card you have.
If you have an AJA Kona LHi (the Kona 3 will not input an analog beta signal), you select something like "AJA Kona 8 bit uncompressed", and go into the AJA Control PAnel (do you know what that is - do you know how to select the Control Panel?), and on the input tab, select ANALOG Component Betacam.
Bob Zelin
