workflow for aja using 23.98 to SD layback
will salas
on Nov 12, 2009 at 4:22:27 pm
so trolling through these forums I found a link that got me half way
http://forums.creativecow.net/readpost/98/869483
this got me to view my material on my program monitor but I still don't see it to output to tape. Not the laying to back but just getting a signal. HELP!
Trying to go from 23.98 to layback to a sd digi tape
it shouldn't be this hard
plus everytime you go to the pull down you change your settings in final cut pro
Jeremy Garchow
Re: workflow for aja using 23.98 to SD layback
on Nov 12, 2009 at 5:40:47 pm
Follow those instructions and it should get you there.
Set FCP in a 720p23.98 VFR easy setup.
Go to the control panel and choose the output , right click on the triangle and choose secondary, then choose 525i.
Go back to FCP.
Should be all good.
Jeremy
