**EMERGENCY** LHe Kernel Panic on Log and Transfer
Uli Kunkel
on Nov 11, 2009 at 4:43:05 am
Trying to digitize tapes. This has worked without a problem in the past.
Just tried loading Log and Capture for the first time since installing FCP 7 and my system kernel panics as soon as Log and Capture loads. I suspect this has to do with my LHe card. I tried resolving the problem by installing the most recent 7.1 drivers. No luck.
I just used the AJA Uninstaller to remove all the components from the computer, and I'm about to re-install the new 7.1 drivers and software. If that doesn't work, I will try reseating the card.
If reseating the card doesn't work, does anyone else have any suggestions for what to do?
Thanks for your help. System specs below:
MacPro Intel Quad 3.0
6GB RAM
ATI Radeon X1900 Video Card
Kona LHe
Uli Kunkel
Re: **EMERGENCY** LHe Kernel Panic on Log and Transfer
on Nov 11, 2009 at 5:13:42 am
Using the AJA Uninstaller, restarting, then re-installing the AJA 7.1 drivers did the trick. All is well now, and I'm gonna go change my shorts now.
Hope this advice helps someone at some point.
Uli
