Kona Problem?
Mike Allen
Kona Problem?
on Nov 2, 2009 at 4:53:16 pm
Wayne Carey posted this on the FCP Forum a few days ago. Can someone confirm, deny, and/or explain this? If this is true, does the same problem exist for the LHi?
"Yes, Walter.... Its a Kona 3 using the 7.0 drivers. And just to let you know... AJA does not support the 1440 aspect ratio. I just spent the month with tech support pointing out this issue and they have decided that there is a software issue when using non-square pixel formats. AJA software engineering has confirmed this."
Mike
