Downconvert Audio-Crackling
Eric Sternberger
on Oct 27, 2009 at 11:51:38 am
Recently we got a strange issue here with our Kona 3 System (2007 MacPro)
We have 1920x1080 ProRes (SQ) Files. Codec, Sequence & Project-Settings matched.
When we switch the Video settings in FCP to 1080i 10bit we get nothing but garbage on our preview monitors. (one is a Sony Class1 CRT connected via SDI using the downconverted SD-Signal, the other is a Samsung LCD connected via component using the HD-signal) But: On both monitors just garbage.
When we switch to 1080 8 bit Video works (on both monitors), but we get Audio-Crackeling playing the timeline. (Audio monitored over Kona)
I was under the impression that ProRes is 10 Bit! So why the issues? And what has it got to do with audio?
We recently upgraded to Control Panel 7.0. I´m not sure, but I think I havent seen this before that...
gary adcock
Re: Downconvert Audio-Crackling
on Oct 27, 2009 at 12:13:37 pm
[Eric Sternberger] "I was under the impression that ProRes is 10 Bit! So why the issues? And what has it got to do with audio?
We recently upgraded to Control Panel 7.0. I´m not sure, but I think I havent seen this before that... "
Eric
this is one of those - I think you downloaded the driver, but forgot to update the firmware on the card.
the firmware update on the Kona 3 Card is a manual process.
Applications > Aja Utilities > Kona Firmware updater.
[Eric Sternberger] "When we switch the Video settings in FCP to 1080i 10bit we get nothing but garbage on our preview monitors. "
when you change the compression version you need to change the Video Out preset also
Question : why are you converting to UC when working with ProRes files- this is unnecessary the way ProRes was designed..
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Eric Sternberger
on Oct 27, 2009 at 1:47:04 pm
Hey Gary,
appreciate that you are still up :-)
Just updated the firmware, it was already the 64bit Version but it was still outdated (I wasn´t aware there was a newer one)
But the problem persists: No Preview with 10bit Display-Setting, only works with 8bit...
BTW: I´m not recompressing to UC, I stay ProRes. It´s just the display-setting (in FCP)
gary adcock
on Oct 27, 2009 at 2:20:25 pm
[Eric Sternberger] "But the problem persists: No Preview with 10bit Display-Setting, only works with 8bit... "
and you are using the EASY SETUP for your flavor of video and ProRes.
this was an issue in the very first 6.0 driver, I have not seen it on the Kona 7.0 driver.
Make sure you DID NOT install the 64bit driver - correct?
gary adcock
Studio37
Chicago, IL
Eric Sternberger
on Oct 27, 2009 at 3:02:24 pm
The firmware now is: 2008/12/17
The footage was captured on another machine with the "HDV to ProRes"-Easy Setup.
It is 1440x1080 25fps Apple ProRes 422
On the editing-machine we used the AJA 1080i 25 ProRes 422 Easy-Setup for the project. With that we have no Preview. Only when stopped or during scrubbing we see a picture.
When we switch the display-settings to 1080i 8 bit, it works though, but we have crackeling sound...
I also uninstalled & reinstalled the 7.0 driver.
Or is the HDV-ProRes conversion the culprit? It was done with the proper easy setup though...
