Capture and monitor 4 channels of audio
Tom Dempsey
on Oct 23, 2009 at 3:32:31 pm
Hi, I'm using a 2 x 2.6 Ghz Quad-Core Intel Xeon Mac with 12 GB of Ram. Also using a Kona LHi
card and monitoring with an 8 Channel Mackie audio board. I'm wondering if i can monitor
4 channels of audio during a capture? either discreetly or mono. Doesn't make a difference.
Is there any work around?
tomd
Doug Beal
Re: Capture and monitor 4 channels of audio
on Oct 23, 2009 at 8:01:12 pm
Lhi is 2 channels analog and AES you can change pairs to monitor, in the control panel but not 4CH at once.
you would need a de embedder to do that, de embedding the SDI stream to 4 CH analog to get that into your mackie,
or monitor a tape machine in E-E via analog outputs of the tape machine while mixing, or off tape while capturing
Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN
Tom Dempsey
on Oct 24, 2009 at 5:06:47 am
thanks. i appreciate the response.
tomd
