AJA KONA LHi - FCP Playback Thru HDMI to SAMSUNG LED Issues
Thomas Talley
on Oct 22, 2009 at 12:10:04 am
I'm trying to get playback thru my AJA KONA LHi via FCP to my Samsung LED. I'm connected thru HDMI.
I'm seeing video in my viewer and on my screen when my footage is paused, but when I hit play, the footage on my monitor goes green and pixelated.
If I scrub, play at 2x speed or higher, or play in reverse I can see playback on monitor, but standard play is messed up. Ideas?
Footage shot on HPX-500
720p30
FCP Sequence settings:
frame size 960x720
Editing TIme Base 59.94
Audio/Video Settings
Sequence Preset: DVCPRO HD - 720p30
Video Playback: aja Kona 720p59.94 10 Bit (1280x720)
In terms of video playback I've tried every setting under the sun and have been unable to get playback.
cowcowcowcow
Doug Beal
Re: AJA KONA LHi - FCP Playback Thru HDMI to SAMSUNG LED Issues
on Oct 22, 2009 at 2:49:49 pm
did you make this preset?
playback should be aja Kona 720p59.94 8 Bit (1280x720)
Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN
cowcowcowcowcow
Jeremy Garchow
on Oct 22, 2009 at 5:46:04 pm
Use the AJA Kona LHI 720p23.98 VFR easy setup.
This will get you playback, but any new sequence you make will be 23.98 fps. you will have to either drag a 29.97fps clip into that empty timeline and accept the change, or change the fps yourself before adding a new clip. You can then modify an AJA preset for 29.97fps VFR footage by suing the 23.98 templates as your guide.
DVCPro HD is 8bit so you need the 8bit output setting.
Jeremy
Tommy Talley
on Oct 22, 2009 at 9:04:00 pm
Yay Playback!!!
Thanks fellas.
Would either of you mind explaining the reasoning behind that adjustment?
tommy talley
contrastfilms.net
tommy@contrastflms.net
"Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you." - Herman Blume
Jeremy Garchow
on Oct 22, 2009 at 11:02:23 pm
As mentioned before, Dvcpro HD is an 8 bit format. You had 10 bit output. There was a mismatch in what was needed to properly play back the footage.
