LHe sync issues, all of a sudden
David Jahns
on Sep 9, 2009 at 5:19:47 pm
I'm not an engineer, just the most tech savvy editor at a shop with 11 FCP Stations - 9 with LHe, one with a K3, and one LHi, all using FCP 6.0.5.
All of the LHe stations are about 2 years old Mac Pros, running 10.4.11, and the K3 and LHi are running 10.5.6. (The CPUs are newer.) This is essentially the same setup we've had since FCP 605 came out in the spring, and it's been very stable.
Now, within the last 2 weeks, 6 of the 9 LHe's have started to have sync issues, during capture and playback, in NTSC, 720p, and 1080psf - digitizing both locally and to the SAN, both using house sync and free run. The LHi and K3 stations have been fine.
We even swapped out a brand new LHe into one of the problem stations, and the sync issue still occurred. I'm at an absolute loss for what to try next. Nothing I can think of makes any sense why 6 of the workstations would suddenly go bad - they're still running the same OS, same versions of QT, same house sync, etc...
Our engineeer consultant is also baffled. Anyone have any ideas?
Jeremy Garchow
Re: LHe sync issues, all of a sudden
on Sep 9, 2009 at 7:08:06 pm
Sync as in a/v (audio/video) sync, or sync as in h/v (horizontal/vertical) sync?
Jeremy
David Jahns
on Sep 9, 2009 at 7:11:14 pm
SYNC as in audio drifts out over time.
about 3-4 frames per minute. When you stop and restart the timeline, it corrects itself - but when digitizing, the quicktime file is actually out of sync if the capture is more than 20 seconds or so.
Jeremy Garchow
on Sep 9, 2009 at 7:19:23 pm
[David Jahns] "SYNC as in audio drifts out over time. "
Yeah, but there's also sync as in rolling picture, you didn't specify, so I asked.
[David Jahns] "When you stop and restart the timeline, it corrects itself "
This is probably a case of not doing either a fully complete render or audio mixdown before layoff. Doing an audio mixdown render is quick and easy, select all, hit command-option-r. This basically renders all audio into one complete and temporary file (with channel selections in you have them) for easier playback. This helps in minimize any rogue audio files that are strewn around the system/different drives.
[David Jahns] "but when digitizing, the quicktime file is actually out of sync if the capture is more than 20 seconds or so. "
This usually indicates that your drives aren't slow enough (are the dropped frame warnings turned in your FCP prefs?) or that your easy setup isn't matching your incoming format. Are you capturing now or logging and capturing?
Jeremy
David Jahns
on Sep 9, 2009 at 10:53:12 pm
Thanks, Jeremy.
If this were one workstation, or a new user, those might be useful suggestions, but things have worked just fine for years - and nothing has really changed in our workflow/process - (except that I've noticed a few different versions of quicktime on different machines - damn iPhone users, updating their quicktime w/o authorization!)
I've double checked all of the workflow/settings - it's not user error. Something has changed in our setup or OS's, and it's damnedest thing I've ever run across here...
I suppose we can try the mixdown as a workaround, but that doesn't help with the digitizing, and our SAN is running just fine - plenty of bandwidth available. Even digitizing NTSC locally to a RAID doesn't solve it, so it's not a drive speed issue either...
Jeremy Garchow
on Sep 10, 2009 at 3:23:54 pm
[David Jahns] "(except that I've noticed a few different versions of quicktime on different machines - damn iPhone users, updating their quicktime w/o authorization!)"
That's not good for the SAN is it?
[David Jahns] " Even digitizing NTSC locally to a RAID doesn't solve it, so it's not a drive speed issue either... "
Yeah, that would seem to indicate something, unless your SAN is goofing it up. How are you attached to it?
Jeremy
David Jahns
on Sep 10, 2009 at 8:05:49 pm
we're using EditShare, which is a gig-E based system.
But the sync issues during digitizing happen even we're completed disconnected from the network - just local storage, and SDI to the deck - both with house sync and on free run.
By the way... how do you quote someone else's message in your posts?
Eyal Dimant
on Sep 17, 2009 at 9:58:04 pm
I know its unlikely that this is the case across 9 machines, but I find when the FCP scopes are up on machines with the LHe it throws my sequences out of synch, on both client and computer monitors.
Hope it helps.
Eyal Dimant
Threehead Studios Inc.
http://www.threeheadstudios.com
Francois Stark
on Jan 8, 2010 at 4:03:30 am
Hi
Have you found any solution to this problem? Did these six suites run without any sync problems before?
Francois
Regards
Francois
David Jahns
on Jan 8, 2010 at 6:37:50 pm
Actually, YES I DID!! (But it's quite unlikely to work for anyone else, I'm afraid, we had a very unique issue.)
I meant to write a follow up, but it slipped through the cracks.
I work in the 12 person Post Production Dept of an Ad Agency (with 400 other people), and we probably have 250 Mac systems throughout the building. Unbeknownst to us, our IT Dept had remotely installed "listening" software called JAMF that allowed them to remotely install upgrades & perform IT tasks - updating MS Office, etc... There was no application to be seen, only a folder in the Library / Frameworks folder of the boot drive.
I found this after re-installing a system from scratch - wipe the drive, fresh OS, etc... testing it out, and it worked perfectly. After IT installed MS Office, the sync issues returned! I was about to lose my mind!!! But we traced it down to the secret "remote install" software, not actually MS Office.
As soon as we removed the JAMF frameworks - the sync issues disappeared completely on ALL systems.
As you can imagine, we had a pretty serious "Keep your IT hands off our systems!" chat after that, and ever since, we have not had a single sync issue. Hurray!!!
If anyone needs more details about the JAMF software, just let me know.
Kevin Camp
on Aug 9, 2010 at 9:11:33 pm
hi david,
we've been having audio sync issues with one fcp station, and it happens to be the only one with the ms office suite installed on it. our it guy is currently on vacation right now, so i can't ask him if he is running jamf, or anything like it.
if i was to search that mac for 'jamf' would i find the software, or can you point me to where i might find the offending software to try removing it to see if that solves our issue too....
thanks
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
David Jahns
on Oct 12, 2011 at 7:03:47 pm
Hi Kevin.
I was just refreshing my memory about this JAMF issue and saw your post from a year ago. Did you get this resolved?
if not, let me know - I'll be happy to share the JAMF KILLER terminal commands I know.
Dave
David Jahns
Joint Editorial
Portland, OR
