Mono audio mix coming from SDI card in monitor
Paul Griffiths
on Sep 8, 2009 at 12:38:15 pm
Hello, I wasn't sure where to post this but here goes...
I've got an odd problem. All new kit...
FCP 6
Mac Pro
AJA Kona LHe with breakout box.
JVC 15" CRT with IF-C21SD1G SDI board
<img= "http://www.bhphotovideo.com/images/images345x345/302405.jpg">
AJA Kona LHe SDI out feeding to SDI in on IF-C21SD1G board in JVC monitor.
Embedded audio from SDI board Analogue out Channels 1&2 feeding via sperate RCA outputs to mixer (then on to speakers)
If I feed a stereo source from FCP - i.e some tone swapping from left and right then the mixer registers a constant mono signal on the input, rather than one swapping from left to right.
To check the SDI output if I feed it to a deck, the meters show a stereo SDI embedded input swapping from left to right.
My SDI board seems to be mixing the SDI feed to mono and I've no idea why.
I checked the manual and my DIP switches on the board match Channel 1 feeding to Channel 1 and Channel 2 feeding to Channel 2.
I'm a little stumped.
Any ideas? :)
hoping,
Paul
