will kona2 do 1080p?
mark pigott
on Aug 31, 2009 at 4:16:20 pm
From the original spec sheet it says that the kona2 will only do 1080i;
will it do 1080p with some type of driver update?
gary adcock
Re: will kona2 do 1080p?
on Aug 31, 2009 at 4:40:37 pm
[mark pigott] "From the original spec sheet it says that the kona2 will only do 1080i;
Ok
couple of things
that card is not longer being made
it was always capable of handling P/ PsF correctly depending on your format.
Yes the current driver build
http://www.aja.com/ajashare/AJA_Kona2_6.0.3.zip
AJA Driver Compatibility as of KONA Version 6.0.3 is as follows:
FCP 6.0.x - Kona Driver version 6.0.3 (Leopard and Tiger OS compatible version)
FCP 6.0.x - Kona Driver version 5.0 through 5.1 NDD (Leopard and Tiger OS-
compatible versions)
FCP 6.0.x - Kona Driver version 4.0 (Tiger OS compatible version)
is good thru FCP 6
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
