Using Audio inputs for voicework
Michael Nichols
on Aug 24, 2009 at 7:47:29 pm
Just curious. I have a 4 channel, powered mixer. Maybe with Logic or Soundtrack Pro (or even FCP), can I use the line outs from the mixer into the inputs on the breakout cable and capture live Audio through the Kona 3?
Abel Cine Tech - Rental Coordinator
We now have Red and SI-2K in our Rental Fleet!
212.462.0163 • mnichols [at] abelcine [dot] com
Jeremy Garchow
Re: Using Audio inputs for voicework
on Aug 25, 2009 at 12:10:46 am
Sure. You'll want to send a stable video source to it for reference, though. You don't have to capture video, it doesn't need anything fancy, just a stable video signal.
Michael Nichols
on Aug 25, 2009 at 12:31:20 am
Will bars from a signal generator be sufficient?
John Fishback
on Aug 25, 2009 at 2:03:51 pm
Yes.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
James Sullivan
on Aug 25, 2009 at 8:15:16 pm
The KONA 3 is digital only. It does not have analog inputs!!!
James Sullivan
John Fishback
on Aug 25, 2009 at 8:22:47 pm
Wow. Forest <> Trees! Of course, it's AES audio in only. We feed analog signals to our Kona 3 with the AJA IO or our digital audio console.
John
Jeremy Garchow
on Aug 25, 2009 at 8:34:40 pm
woops, for some reason I saw LHe.
My mind's playing tricks on me.
Jeremy
