K3 Box Video Out
Gerry Condez
K3 Box Video Out
on Aug 20, 2009 at 5:56:25 pm
Hi Guys,
Finally my setup is working. My question right now is how to monitor video from the K3 box. I saw the component out but my monitor is 4:3 with component. My other 16x9 only has composite ins. Is it possible to do just composite and which output should I use from the K3 Box.
Do I need a mini converter to monitor?
Thank you,
Gerry
Shane Ross
Re: K3 Box Video Out
on Aug 20, 2009 at 9:11:40 pm
The K-Box has Composite out too...the Y/G/CVBS is a composite out as well. Just choose that in the Kona Control Panel and you should be good to go.
Shane
