Weekend Kona LHi woes
Jim Curtis
on Aug 8, 2009 at 5:12:59 pm
Hi everybody. Long time lurker, first time poster.
I just got a Kona LHi on Thursday for my early 2008 MacPro. 32G RAM; 10.5.6, QT 7.5.5; FCS2 (FCP 6.0.5); Adobe CS3. LHi card in slot 2, per AJA web site. Installed the 1.1.1. NDD driver package (after having worse luck with the 6.5 set, and uninstall).
I have a case going with AJA Tech Support, but since it's Saturday, I don't expect to hear from them until Monday.
I'm having sync problems with most apps that use the card (testing w/ XDCam EX footage 29.97):
FCP audio starts in sync, then drifts. Audio sounds "choppy."
AE RAM Previews: starts in sync, drifts quickly, causes AE to crash.
STP: clips play in sync, but video is dropping frames while staying in sync with audio
Premiere Pro: crashes after the LHi is chosen as the hardware device, and Play is invoked.
AJA TV: audio plays, but video is black, no matter what setting in the Display menu. Works fine with SD material.
Before installing the Kona LHi, I had virtually no issues with these applications. They all work great without the Kona selected as the hardware device.
I read in other threads, that Mr. Zelin suggests another PCI slot than the one recommended by AJA for the LHe card. I may try another slot, so see if that helps. In the meantime, if anybody has any suggestions, I'd be grateful to hear them.
Jim Curtis
Bob Zelin
Re: Weekend Kona LHi woes
on Aug 8, 2009 at 5:46:33 pm
open up the expansion slot utility (do you know where it is ?).
You say that you have an early 2008 MAC Pro - so it probably uses the Expansion slot utility. Make sure that your card slot is a x4 slot. NOTHING (no storage card, no AJA card) can operate as a x1 slot.
Bob Zelin
Jim Curtis
on Aug 8, 2009 at 6:13:52 pm
I, in fact, did not know where Expansion Slot Utility was, but I found it with my trusty EasyFind app.
When I launched it: "Expansion Slot Utility is not intended to run on this system." I don't think any of my slots are 1x.
Between my first post, and getting your reply, I swapped PCI cards, putting the LHi card in Slot 3 (4x), and returning my RocketRAID card to Slot 2 (16x), where it was working great before I installed the LHi.
(BTW, my external RAID 5 is off for these tests. I'm using my MacPro internal software controlled RAID 0 for my testing.)
There was no change to the audio sync problem after swapping slots. Still drifting.
I loaded an hour-long DV NTSC Sequence into FCP, and it's playing in sync for long periods. So, this issue seems to be related to XDCam EX at the moment.
Warren Eig
on Aug 9, 2009 at 7:06:11 pm
Early Mac Pro 2008 don't use the Express slot. They are fixed bandwidth. The 2007 and 2006 Mac Pros use the express slot utility.
Warren
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.babyboompictures.com
http://www.babyboompictures.com/BabyBoomPictures/AFX.html
http://www.babyboompictures.com/BabyBoomPictures/KnitWits_Movie.html
http://www.imdb.com/name/nm0251670/
EDITING REEL: http://www.babyboompictures.com/BabyBoomPictures/Editing_Reel.html
TITLE DESIGN: http://www.babyboompictures.com/BabyBoomPictures/Titles_Reel.html
Jim Curtis
on Aug 9, 2009 at 7:49:41 pm
I don't know what I did, but it's working now, and the audio is staying in sync with XDCam EX footage.
I was experimenting with different footage I had on my drives. SD NTSC was working great. HDV 720p material was working great. I made Presets for each in the AJA Control Panel. So, with those successes, I tried loading up the same two XDCam EX projects that were out of sync before, and this time they were playing in perfect sync. I guess toggling around settings in the CP did something to reset the card or something. I have no other good explanation. Magic, maybe.
I left the LHi in PCI Slot 3. (4x)
I do have two other slight issues with the card, though: When 525i (NTSC) is chosen as either the primary or secondary output via YC analog, the image is slightly washed out, including the color bars generated by the LHi when FCP isn't the controlling application.
And the card doesn't seem to be using all the raster on my CRT (Sony PVM-9L3, which has been very trusty about displaying a well-calibrated image). IOW, the LHi seems to be scaling down the image to the YC output. I see the entire raster even when the monitor ISN'T in Underscan mode. With other inputs, there is normal TV cut-off. But with the LHi, I'm seeing a black border around the image in normal scan mode.
